wobbly door lock
trisarahtops
wobbly door lock
by trisarahtops » Wed Aug 04, 2010 1:33 pm
My front door has a (yale type) lock on it and the panel on the outside of the door where you insert the key has a lip that you have to grab in order to shut the door as there is no doorhandle.
The panel at the front has become wobbly-is there an easy way to tighten it?
Thanks!
by stoneyboy » Wed Aug 04, 2010 11:40 pm
trisarahtops,
"is there an easy way to tighten it?" Yes remove the lock body - usually 2 screws on the edge of the lock, this will expose the two fixing screws which hold the outside lock in place. Tighten and refit.
It is currently Thu Jan 09, 2025 6:30 am
