Rope Top Blocks - Fixing and Painting
skint4sure
by skint4sure » Thu Aug 05, 2010 6:20 pm
Hi all
I want to get 4 blocks and 2 corners and paint them black with gold tops.
I want to put them in the gorund in front of a headstone so they are visible above the earth and then fill in the space with chippings or similar.
I need to know:
What bond/solvent to use to fix the end corners to each block tight and remember it's outdoors so exposed to all elements weatherwise.
What kind of paint to use. I can't locate gold in masonry paint but would some other kind be better and longer lasting.
Should I be digging a small trench and filling it with concrete first to form some solid base so the blocks won't sink into the earth.
Thanks for all your help.
It is currently Thu Jan 02, 2025 11:25 pm
