Thermostatic Shower installation
Eddiec
by Eddiec » Thu Aug 05, 2010 8:37 pm
I own a BAXI Combi 80eco. Looking to install a thermostatic shower but not sure if the pressure is suitable. Water flow rate at maximum setting is 9 litres / min. (also what does maximum setting entail).
Any help appreciated.
plumbbob
Re: Thermostatic Shower installation
by plumbbob » Sat Aug 07, 2010 5:35 pm
Eddiec wrote:I own a BAXI Combi 80eco. Looking to install a thermostatic shower but not sure if the pressure is suitable.
The pressure has little bearing on how well a mixer shower will work. What is important is the flow rate which is determined partly by the boiler and partly by the incoming mains water supply.
You can calculate flow rate by timing how long it takes for your existing hot supply to fill a lemonade bottle. Check this against the manufacturers data for the shower you would like to fit.
I am not sue what you mean by "what does maximum setting entail"
Eddiec
thermostatic shower
by Eddiec » Tue Aug 10, 2010 5:17 pm
thanks for help.
I will use the bottle method with the manufacturers data
The pressue comes directly from the mains and has high pressure rate (flow rate) whic should be helpful however as you say the flow from the boiler is also imprtant.
The maximum setting was the description per the boiler details, however your explanation is of great help
thanks again
It is currently Fri Jan 10, 2025 9:06 am
