Outside Lighting PIR Operated
simondatws
by simondatws » Tue Mar 06, 2007 1:28 pm
I have three outdoor wall mounted lights, the one furthest from the front door has the PIR. This light also has the wires from the indoor switch to it and one other black wire. The other two lights have one set of wires L,N,E to them and operate with the PIR light is triggered. I now want to change the light with the PIR to the one nearst the door. How can I acheive this? All the wiring is enclosed in the walls.
stanley
by stanley » Wed Mar 07, 2007 9:32 pm
you would need to put a new switch in by the front door, or conduit the existing wire across the outside wall to the door light, then wire up as it is currently
thedoctor
by thedoctor » Fri Mar 16, 2007 2:34 pm
MANY OF THE ANSWERS TO YOUR POSTS CAN BE FOUND, WITH DIAGRAMS, IN THE DIYDOCTOR PROJECTS SECTION. CLICK HERE www.diydoctor.org.uk/projects.htm
stan
by stan » Sun Mar 25, 2007 9:11 pm
how do i fit an overide switch to a security light to enable it to be switched on and off , the light is wired as normal with live,neutral,earth.
It is currently Sat Nov 23, 2024 2:28 pm
