18 degree sloping roof tiles
Simon Lewis
by Simon Lewis » Thu Aug 12, 2010 7:20 am
I am building an extension and the roof will only have an 18 degree pitch. The house has existing Rosemary tiles 100 years old. I am told I cannot use these as they will not suit a fairly flat roof. Can anyone suggest tiles similar that will ? Thanks.
Perry525
by Perry525 » Fri Aug 20, 2010 6:20 pm
The roof is too flat to be tiled.
However, I can understand your wanting it to match in.
The solution is to cover the building with waterproof marine ply nailed and glued, cover that with waterproof plastic membrane with sealed edges, then double batten, to enable the rain water that will blow through the tiles to run away, then tile.
angielily18
by angielily18 » Mon Aug 23, 2010 4:09 pm
An eighteen degree roofing would be not really fitted on a tile roof. The angle is unsuitable, you should adjust it into a tipper angle.
It is currently Sat Jan 04, 2025 1:51 am
