no cold water coming out off mixer tap in kitchen
andy foster
by andy foster » Wed Aug 18, 2010 6:35 pm
hi can anyone help me i have no cold water coming out off my mixer taps in kitchen hot is fine :?:
by stoneyboy » Thu Aug 19, 2010 6:52 pm
andy foster,
Have you or anybody else (shared supply) turned off the mains, have you paid your water rates. Is the wheel head turning without actuating the spindle????
kal
by kal » Thu Aug 19, 2010 10:54 pm
have you got cold water anywhere ells? (Should hv otherwise where is the hot water coming from)
Find the cold water pipe under the sink/basin, if you run the hot, feel for the hot pipe (thats not the one), if you have a compression fitting on the pipe, undo it slightly and check for water supply.
If you get water then it’s the mixer, if not let me know..........
:roll:
kal
Re: no cold water coming out off mixer tap in kitchen
by kal » Thu Aug 19, 2010 10:55 pm
andy foster wrote:hi can anyone help me i have no cold water coming out off my mixer taps in kitchen hot is fine :?:
It is currently Fri Jan 10, 2025 9:00 am
