Programastat TRT037 wireless room thermostat
scotorca
by scotorca » Fri Aug 20, 2010 7:49 pm
Can anyone please help with the connecting of the above? There is a wiring diagram, but I just don`t understand what to do. Any help would be greatly appreciated.
by sparx » Sat Aug 21, 2010 10:03 am
looking at instructions it looks pretty simple to me.
Depends on your system, but for a combi you put RX(receiver) next to boiler and loop a L & N supply to it then bring the boiler switch line(call) from N/O term. of RX
It appears to need a link between L & Common terms. (or another wire from boilers control out if a Bosch-Worcester)
Put batts in remote unit and set up.
If using a non combi set up there are too many variables to guess without knowing your system.
scotorca
by scotorca » Sun Aug 22, 2010 2:20 pm
[quote="sparx"]Hi,
If using a non combi set up there are too many variables to guess without knowing your system.[/quote]
[b]Hi, thanks for the quick response. The boiler is not a combi, it is a Baxi Solo 3 PFL range with powered flue if that helps?[/b]
It is currently Tue Nov 26, 2024 3:46 am
