UPVC FRONT DOOR
GMC333
UPVC FRONT DOOR
by GMC333 » Fri Aug 20, 2010 7:55 pm
Just fitted a front door in UPVC frame and door.
I now need to fit a moulding in UPVC around the door to cover the tiny gap between the door and frame .
The mouldings that I have are UPVC , can you recommend a glue to stick these two together . NO nails etc. don't work .
Thank you in advance
by stoneyboy » Mon Aug 23, 2010 11:50 pm
GMC333,
If the mating surfaces are smooth use superglue with an accelerator.
If not use a neutral cure silicone mastic.
It is currently Mon Dec 23, 2024 12:43 pm
