Repairing a clay drian pipe
damian
by damian » Tue Jun 12, 2007 12:19 pm
Hi.
Can anyone tell me what I need to repair a crack in a clay drain pipe?
I have plastic drain pipe running down from my gutters in to a clay grid.
The grid is connected to a clay pipe, and there is a crack on the top of this clay pipe that I want to repair.
The crack isn't really causing me a problem as no water is running out of it and it's not connected to a soil pipe anywhere, I'd just like to get it sorted before it gets any worse.
Thanks for your help/suggestions.
Regards,
Damian
thedoctor
by thedoctor » Fri Jun 15, 2007 6:46 am
There is a tape available from builders merchants called Densotape. It is used for pipe wrapping as insulation and protection but will make a good temporary repair to a clay pipe. We strongl;y suggest that you get the pipe replaced however as the ground is moving all the time and a small crack now can be a broken pipe in 6 weeks time leading to all sorts of problems. It wioll be much cheaper to replace it now that to gig it all up again.
It is currently Mon Nov 25, 2024 10:42 pm
