Fixing plasterboard over existing ceiling
Pastyman
by Pastyman » Wed Aug 25, 2010 5:30 pm
In our single storey spare room it appears there is no insulation above the plastered ceiling board. It is a sloping ceiling. I want to add a layer of Gyproc Thermaline Insulation board and have it plastered again to increase the insulation. I assume I have to screw the board in place so is there any easy way of finding the existing rafters? Thanks.
neald
Re: Fixing plasterboard over existing ceiling
by neald » Tue Sep 07, 2010 8:53 pm
[quote="Pastyman"]In our single storey spare room it appears there is no insulation above the plastered ceiling board. It is a sloping ceiling. I want to add a layer of Gyproc Thermaline Insulation board and have it plastered again to increase the insulation. I assume I have to screw the board in place so is there any easy way of finding the existing rafters? Thanks.[/quote]you could use a stud detector or knock some holes out with a hammer and chisel to locate the timber
It is currently Sun Nov 24, 2024 1:57 am
