Wiring Diagram for AHY4301
busylizzy
by busylizzy » Thu Aug 26, 2010 9:55 pm
Dear All HELP
I have a Diplomat 910 AHY4301 which has a blue wire that is joined from the top left hand terminal of the grill and then joins the middle square element between the two ovens but the end of it has come away from it connection .....Is it one of the terminal connections at the bottom right hand corner where the mains is attached as all the other wires which are in the back of the over all loop around to this spot but there are two free terminal connections the top two, which one do I connect it to??
I have just spent £100.00 to replace the elements and the door gaskets and really want this to work now
Any sound advise would be much appreciated.
Ta Teresa :roll:
It is currently Tue Nov 26, 2024 7:30 am
