Parliament Hinges
2njoylife2
Parliament Hinges
by 2njoylife2 » Sun Aug 29, 2010 2:34 pm
Could you please help me with parliament hinges.
I have 2 glass panel doors which I have put 3 parliament hinges on each door, with the doors swinging out looking at them the left hand works prefect but the right hand door I am lots of problems with it.
The frame is plumb and square and my problem is the right hand door drops on the inside bottom and there is a gap on the top left hand corner and I am not sure why.
You can put a wedge under the left hand bottom and it lifts the door and closes the gap on the right hand top hinge. You can push the top left hand side and it closes the gap where the hinge is. What is the problem please
Mandi
by stoneyboy » Fri Sep 03, 2010 12:05 am
2njoylife2,
Screws are loose, tighten and you should be OK.
It is currently Fri Jan 10, 2025 8:10 pm
