Triton Jade 2 Fault
Mark L
Triton Jade 2 Fault
by Mark L » Tue Aug 31, 2010 2:40 pm
Our Triton jade 2 has worked fine for two years or so but now has stopped working - no water hot or cold. When the on button is pushed, the 'Low Pressure' light comes on and basically nothing happens, not a gurgle or a drip. Is something blocked on the cold water feed side or is it just dead? Advice much appreciated.
Mark
plumbbob
by plumbbob » Wed Sep 01, 2010 11:44 pm
It could be a blocked inlet filter, but if there is no water from the shower head at all, the most likely culprit is a failed solenoid inlet valve.
Mark L
by Mark L » Fri Sep 10, 2010 10:32 am
Thanks for that - have ordered the part and will be fitting soon, any tips on fitting it, just on the off chance it proves difficult??
plumbbob
by plumbbob » Fri Sep 10, 2010 5:45 pm
I don't think there is any particular issue with fitting a valve, although you may find the whole unit will have to be removed from the wall as you might find difficulty with disconnecting the incoming water connection.
It is currently Fri Nov 15, 2024 3:46 pm
