Replacing outside light
Frisby
by Frisby » Sat Sep 04, 2010 6:34 pm
I need to replace an outside light but when I switch the electricity off my intruder alarm goes off. Could I get away with just ensuring it is switched off at the switch?
by stoneyboy » Sun Sep 05, 2010 11:21 pm
Frisby,
Without further information not a good idea.
Can you turn off the circuit for the lights which feed the outside light and leave the alarm on?
by ericmark » Mon Sep 06, 2010 12:31 am
Not really.
1) The switch is likely single pole so there could be power on neutral wire.
2) It could be wired like internal lamps where line goes to the lamp first.
I would think changing the battery in alarm is right way to do things. There are normally two batteries on in bell and one in panel and if latter is faulty then alarm will sound with power cut.
Frisby
by Frisby » Mon Sep 06, 2010 11:54 am
stoneyboy wrote:Frisby,
I don't think so - there is a switch in the house and also one in the garage but they both trigger the alarm. Thanks for your reply, though.
Frisby
by Frisby » Mon Sep 06, 2010 11:56 am
ericmark wrote:Not really.
Thanks for the help - I will contact my alarm people as it has only just been serviced.
It is currently Thu Jan 16, 2025 10:45 am
