combined bath and shower waste run
mscg
by mscg » Tue Jun 12, 2007 8:33 pm
is there a specific type of trap that will prevent bathwater finding its way back along the shower waste or is the seal created by the water in the shower trap sufficient. the trap that was there was a low level bath trap with anti-vac - could i replace with a basic bottle trap or with the pressure created by the head of bath water push the trap out
thedoctor
by thedoctor » Wed Jun 13, 2007 8:24 am
There is no "specific" trap as its expected that both units will have enough fall to prevent this possiblity. A bottle trap is not recommended for a bath but you can put a normal s bend on.
smithy
by smithy » Tue Jun 19, 2007 9:39 pm
If you have only a slight fall on your waste pipes.
you could insert a inch and a half Mcalpine non return waste valve, to combat waste water from bath being forced up into shower tray.
they are available from plumbers merchants or even B and Q and Wickes.
Hope This Helps,
Smithy
It is currently Thu Dec 12, 2024 9:39 pm
