Moving header tank
dns
Moving header tank
by dns » Fri Sep 17, 2010 12:14 am
Hi guys and girls,
My flat has a conventional hot water cylinder with immersion heaters, fed from a header tank positioned just above it in the airing cupboard.
I've got a large loft, so was wondering about maybe moving the header tank. I'd be able to place it immediately above where it is now.
I'm thinking of doing this simply so I have a lot more storage space in the airing cupboard. I have a pump on both the hot and cold water, so the pressure is great regardless of how high the header tank is.
I'm a fairly competent plumber, no problem with soldering etc, but have never moved a header tank before.
Anyone got any tips for me? Anything I should be aware of before I start?
plumbbob
by plumbbob » Sun Sep 19, 2010 8:50 pm
Try to avoid lengthy horizontal pipe runs.
Other than that, it should be straightforward providing you support the tank sufficiently and lag it well. Make sure it has a tight fitting lid to avoid nasties getting in and contaminating the water.
dns
by dns » Tue Sep 21, 2010 1:06 am
Thanks plumbbob.
The new tank will be immediately above the old one, so barely any horizontal run.
It's got a sealed lid so nothing should get in.
Cheers for the tips.
It is currently Fri Nov 22, 2024 7:38 pm
