Fitting a spy hole on a upvc door.
gazza21
by gazza21 » Sat Sep 25, 2010 11:12 am
Hope you guys can help I want to fit a spy hole to a upvc door but there is a small section at the top of the door with glass. What I was wanting to know was how could I fit a spy hole with this or check how far the glass panel runs inside the door. Help me out guys. Cheerz
door
by welsh brickie » Sat Sep 25, 2010 7:35 pm
hi gazza
The door panel is usually composed of compressed polystyrene with a skin of pvc on each side the glass will only by fitted with 10mm hidden so if you allow 50mm min you will be fine it fit spy hole
It is currently Fri Jan 10, 2025 8:08 pm
