fitting very narry dg window
pacman
by pacman » Tue Sep 28, 2010 9:27 pm
hi, I have some narrow pvc windows to fit. The frame size is 340mm x1160mm and the gap slightly wider.
Now I can't fit my drill in that gap to drill horizontally to the blockwork.
Does anyone know of a small SDS drill including the bit that could fit in that space?
thanks in advance
fitting
by welsh brickie » Wed Sep 29, 2010 8:18 am
fix metal cleats (brackets) to the pvc vertically on each side of the pvc frame before fitting,and fix to the window reveals, your able to angle the drill and fix the brackets to the brickwork rather than drill through the frame.
pacman
by pacman » Wed Sep 29, 2010 2:24 pm
thanks welsh brickie
are cleats and lugs the same thing?
are there universal ones or do you need to get ones to fit the particular extrusion the windows are made of?
most prob synseal 70mm extrusions.
cheers
by welsh brickie » Wed Sep 29, 2010 7:30 pm
you can use anything really, I have used wallplate straps cut to size so long as they are galvanised.There are proffesionally made stainless steel ones also,but are expensive
It is currently Mon Dec 23, 2024 3:01 pm
