Drive Cracking around Manhole
beadie
by beadie » Wed Sep 29, 2010 1:39 pm
I have a manhole cover in the drive and the tarmac is cracking around the edge. How can this be repaired. Is it easy or do I need a proffesional.
It is not too bad at the moment but I imagine if I keep putting the car over it, it will gradually get worse.
Any help gratefull.
by stoneyboy » Wed Sep 29, 2010 11:25 pm
beadie,
Rake out the loose stuff, coat the recess with bitumastic paint and fill with repair tarmac.
beadie
Links?
by beadie » Fri Oct 01, 2010 8:04 am
Thanks for the resposne. Being a complete novice can you post some links as to where I can get these products?. Thanks.
by stoneyboy » Sat Oct 02, 2010 10:00 pm
beadie,
Try your local builders merchant and ask for cold lay tarmac - it comes in 25kg bags.
It is currently Tue Nov 26, 2024 6:06 pm
