pressure vessel
jsgreg
pressure vessel
by jsgreg » Mon Oct 04, 2010 9:32 pm
Have pressured system with ZILMET 130-cal-pro pressure vessel. Over the past few days have had to re-pressurize it every day been told it is possible to pump it up with air it is fitted with a valve oposite end to water in let. Can it be pumped up to solve the problem or does it mean a new vessel?
by stoneyboy » Mon Oct 04, 2010 11:09 pm
jsgreg,
If by "had to re-pressurize it every day" you mean you have added more mains water then there is a fair chance the PV has failed.
It is currently Sat Jan 25, 2025 11:59 am
