Fixing cupboards to wall in garage.
jammy1
by jammy1 » Thu Oct 07, 2010 1:23 pm
Hi all!
I'm getting desperate here. I am trying to figure out a way to attach some heavy cupboards to an extension garage wall. The problem I am having is none of the fixings I use will get tight to assure the cupboard doesn't drop onto my car.
I have experimented with:
* Large screws and rawl plugs, these just spin and pull out.
* I tried 100mm double glazing fittings, but the screw just pulls the plastic end bit right through.
* I tried 110mm rawl bolts, but again, these don't get tight.
It would seem the concrete blocks the builder used are made of corn flakes, and then there is 1 inch of plaster board depth, not including the 3/4inch MDF of the cupboard. There is a cavity just after the blocks, but that is 150mm in after all the layers.
How do I fix something heavy to these walls?
Thanks in advance for any help given,
Toni.
jammy1
by jammy1 » Thu Oct 07, 2010 11:55 pm
Never mind, going the chemical route...
fixings
by welsh brickie » Fri Oct 08, 2010 4:01 pm
you can use 120mm stardrive fixings,You drill a 6mm pilot hole and the screw drives straight into the block eliminating the need for raw plugs you will need a strong cordless to drive the screw home.
It is currently Mon Dec 23, 2024 6:01 am
