gas & gas fitting
squidgy
gas & gas fitting
by squidgy » Thu Oct 07, 2010 11:00 pm
hi can you help? i have a vaillant turbo-max vuw 242e, i had someone look at the boiler when it was leaking water,1st he said an o-ring, so he replaced the o ring, it still leaked, another visit he then said the water was comming from the microswitch. is this possible & how easy is it to fix? he told me it wouldnt be worth repairing?
thank you
by htg engineer » Fri Oct 08, 2010 1:38 pm
Well a microswitch is electrical - so no water there - it may be from the diverter valve around the fulcrum arm - which operates the microswitch - you can a buy a diverter overhaul kits for a few quid - so yeah it is worth repairing as very cheap. Unless he was thinking of repairing the whole diverter - but even then you're only looking at £120ish - if the boiler is in good condition it would still be worth the repair.
htg
It is currently Sat Jan 04, 2025 9:51 am
