by roddymcdowall »
Wed Oct 13, 2010 10:26 am
I understand the concept but I do not see how that will work in practice.
I have a mechanical timer switch that has the timer and also two single ganged switches on it, one for heating and one for hot water. The supply from this switch goes to a control box which has the thermostat lead also going to it.
So I have a thermostat which forms part of the circuit for a relay to a solenoid valve which opens and allows hot water flow to the radiators.
I am considering replacing the mechanical timer switch and the mechanical thermostat.
If I go with a remote thermostat I suppose I will have to purchase a new Timer switch that works with it.
Which unit and brand would you advise? Am I correct to assume that a thermostat that does not use wires is a wireless unit but has does the controller know when the unit is off and on or open or closed?
