Help changing ceiling rose with light dimmer
inch high
by inch high » Tue Oct 12, 2010 1:54 pm
Hi guys,
I need to replace the ceiling rose in my front room. I thought it would be a straight swap but when I've come to do it, the connectors seem different.
Can someone in the know have a quick gander at the two pics below, and advise me how to wire it up please?
http://rob978.fotopic.net/p67643047.html
http://rob978.fotopic.net/p67643048.html
Is there a chance that I've bought the wrong one? Does in need to specifically be a dimmer type?
[/code]
by stoneyboy » Tue Oct 12, 2010 11:12 pm
inch high,
3 red wires go into loop terminals, 2 black wires go into neutral leaving 1 spare for flex, black with red sleeve goes to live again leaving 1 spare for flex.
by ericmark » Wed Oct 13, 2010 9:42 am
There are direct replacements for each other be careful not to loose the red sleeve.
SW = Live (Not really right name should be called Line)
Line loop in = Line
Neutral = Neutral
inch high
by inch high » Wed Oct 13, 2010 1:39 pm
Cheers guys! Will do it later...
It is currently Tue Nov 26, 2024 2:53 pm
