POTTERTON SUPRIMA PROBLEM
vanpeeman
by vanpeeman » Wed Oct 13, 2010 1:32 pm
Hi, does anyone have any suggestions..... I have a Potterton Suprima, its about 10 years old and had a new PCB about 5 years ago. everything has been ok until we went away for a couple of weeks and turned the water heating off. since coming back and setting the water to come on twice a day again, the central heating now comes on with the water heating even though the CH is set to off on the programmer. not sure weather its a boiler or programmer fault. Any help is appreciated. Cheers.
by htg engineer » Thu Oct 14, 2010 8:49 pm
It'll most likely be the three port valve/ actuator at fault.
htg
vanpeeman
potterton suprima
by vanpeeman » Fri Oct 15, 2010 11:49 am
Thanks HTG, where would i find the valve, and is there anything i can do to repair it, or will it need a new one? Thanks in advance.
It is currently Fri Jan 10, 2025 1:13 pm
