use of trenchblocks
vonspritz
use of trenchblocks
by vonspritz » Fri Oct 15, 2010 10:48 am
Hi all
I'm a bit baffled about the use of trenchblocks (laid flat on the footings) versus two skins filled with a weak mix concrete. Most illustrations show two skins, why not just take the trenchblocks to one block below ground level?
Hope this question is clear as it's hard to explain without a diagram.
Vonspritz
trench blocks
by welsh brickie » Fri Oct 15, 2010 5:30 pm
Trench blocks save time on labour costs and is a lot quicker.You dont have to place weak concrete in the cavity,you stop the trench block just below ground level.
It is currently Fri Nov 22, 2024 6:23 am
