Hi. I'm making a drop down loft hatch and I want to use concealed hinges so they cannot be seen from underneath. Would 3 Blim hinges do the trick? What sort of catch should I use? I want a tight a seal as possible and will probably but some rubber draught seal (that's usually used in windows and doors) around the edge.
Hope someone can help?
