Lowering a ceiling - What size timber?
mikip
by mikip » Tue Oct 26, 2010 9:18 pm
I intend to lower the ceiling by about 12 inches in a bathroom of size 2.5m x 3.5m. I am going to construct a frame around the walls and place cross members every 400mm. PLasterboard will be fixed to the frame and pvc cladding screwed to the plasterbaord.
What size timber should be used for the timber framework ? Would 2" x 2" be OK?
Regards
Dan the man
by Dan the man » Thu Nov 11, 2010 4:45 pm
3x2 would be best 2x2 would sag eventually over a period of time.
steve61
by steve61 » Sun Nov 21, 2010 8:53 pm
50mm x 50mm would be ok as long as you used some struts fixed to the new ceiling timbers, extended vertically and fixed to timbers, which in turn are fixed to the existing ceiling joists.
Hope this helps,
Steve
bazl30
by bazl30 » Tue Dec 21, 2010 3:37 pm
i'd go for either 3 x 2 or 4 x 2, its gona be a lot strong as im sure you'll be using 1/2 plasterboard...better job for the sake of a few extra pounds..
It is currently Sat Nov 23, 2024 1:50 pm
