Ceiling lights - No current
tomlinsonr
by tomlinsonr » Thu Jun 14, 2007 1:32 pm
I've been changing ceiling lights in a new flat and noticed that when I came to the hall light there was no current at the switch or the light itself when tested with one of those 'be safe' gadgets. I checked the wiring at the switch and the light terminal and all appears to be in order - just no current. This is strange because a second hall light (a wall light) works as do all other lights in the flat. Is it possible that this one light is on a different circuit (unlikely?) or is it something to do with the wiring.....or something else?
by sparx » Thu Jun 14, 2007 10:26 pm
Hi, I would suggest U go back to the last light U changed b4 U noticed fault & check all connections, especially the looped thro' Lives, (usually 3 reds together), regards SPARX
It is currently Mon Jan 06, 2025 2:26 am
