Help and advice please
Drained my system recently (as i have done previously) to add inhibitor before putting c/h on for the first time this winter and since then the rads are heating up along with the dhw while the programmer is only set for dhw.
Also the pressure guage on our sealed system now runs up to 1.6 bar when hot whereas it used to run at 1.2 max.
The c/h-rads are on a sealed system with expansion vessel. DHW is from a vented tank in the loft. We can normally run dhw and c/h independant of each other or both at the same time.
Worcester Danesmore 12/14 oil boiler, Danfoss programmer and HSA3 3 way motorised valve. Grundfos pump.
I refilled via the filling loop carefully up to 1.0 bar pressure as i have done previously.
Any ideas as to the cause/remedy?
Could it be a faulty 3 way valve and if so could this also cause the increase in pressure?
Apologies if i havent explained it very well but if you can help please let me know what other info might help you to assist me.
Mike
