STRENGTHENING A JOIST
BOILER
by BOILER » Tue Nov 02, 2010 10:12 pm
I need to drill a vertical hole through a floor joist to accommodate a central heating pipe to supply a new c.h. radiator. The problem is that this hole would be next to a redundant hole. I would like to add strength to this weakened region of joist - any suggestions ?
The joist is at the perimeter of a ground floor room therefore one vertical side is inaccessible. Rubble is 600mm/24" below.
Hope I can find a solution before the plumber arrives!
Many Thanks.
It is currently Mon Dec 23, 2024 7:58 pm
