by Pivotal »
Thu Jun 14, 2007 3:15 pm
A few days ago we stopped getting hot water, I noted that the gauge on the boiler way low but not on the bottom so I added some more water into the system, but still no hot water. When I boost the HW or when it should be on, no activity at the boiler.
Ive checked that the CH work & thats fine, the boiler lights, I can hear the system moving water & the pipes warm up by the boiler & radiators.
The 3 way divertor by the bopiler was very warm even when the pipes were cold, I powered the system down & the heat disapated. It didnt come back on when I tried to boost the HW.
I found the manual override on the Diverter & after a short while the motor got hot.(I powered down the system & having taken off the cover saw the cam rotate away from the microswitches. I couldnt tell if the shaft was rotating anything.
Ive tried testing CH thermostat down, boiler sensor full & boosting, but to no avail, no noise from the boiler, pipes or anything, no ignition of the boiler.
I havent tested any voltages
Boiler - glow worm ultimate 44FF
Diverter - Honeywell (not clear model)
We live in an area where the build up of scale is evident but not excessive.
Any thoughts further test etc appreciated.
