Bathroom heated towel rail.
snowie
by snowie » Thu Nov 04, 2010 2:20 pm
Looking to fit an electric heated towel rail in the bathroom. The element wiring will go through the plasterboard wall, to connect to a fused socket in the hallway. Do you just push the wire through a hole in the plasterboard, or is there something a bit 'neater'?
Something which looks a bit like a TV socket plate, but doesn't do anything except look neat? Something like this?
http://www.awin1.com/awclick.php?mid=1228&id=61071&p=http://www.screwfix.com/prods/23144/Electrical-Supplies/Switches-Sockets/Stainless-Steel/Volex-Flat-Plate/Volex-TV-Skt-Brushed-Stainless-Flat-Plate
by ericmark » Thu Nov 04, 2010 5:53 pm
I would use a cooker outlet http://www.awin1.com/awclick.php?mid=12 ... ker-Outlet but any item fixed i.e screwed to wall comes under Part P so the work as it involves a bathroom will need registering. I would as the LABC what he will accept before you do the work. There is also the grid switch route all sorts are available.
It is currently Sat Dec 28, 2024 5:19 am
