My balls up... Need to fix a radiator to the wall.
The_Blade
by The_Blade » Tue Nov 09, 2010 9:45 pm
Hello all,
I'm a newb to the forum and need a little help. We have a victorian radiator in our bathroom (plumbed in). Our bathroom got kitted out a little back-to-front in terms of which jobs should have been carried out first.
Anyway here's my problem. The rad is plumbed into the central heating and needs fixing to a tiled wall. There are fixing plates which attach to the wall and the rad is secured via small screws to the fixing plates.
I have virtually no acces to drill into the wall to get the plates secured.
Anything I can do myself or is it a plumber job?
Any help most welcome...
Neil
by htg engineer » Thu Nov 11, 2010 8:00 pm
Does the base/fixing plate not screw off the towel rail?
if not - You're going to have to remove the radiator, not necessarily a plumbers job.
Mark holes, turn both radiator valves off, undo the nuts on the radiator and allow water to drain into a dish.
Re-fit and refill, if you have a pressurised system you will have to re-pressurise via filling loop
htg
It is currently Sat Jan 11, 2025 9:12 am
