Which water pump?
Essential Bathrooms Ltd
Which water pump?
by Essential Bathrooms Ltd » Wed Nov 10, 2010 5:41 pm
Can anyone recommend or advise on a suitable single-impeller, positive head pump to boost hot water pressure on a vented tank system in a 4 bedroom family home? The house is a good size with two bathrooms, large kitchen, and a downstairs cloakroom. The hot water cylinder is on the first floor and the pump will be installed at its base in the airing cupboard.
I have never brought or fitted a pump for this application so any help would be appreciated!
Many Thanks!
by stoneyboy » Sun Nov 14, 2010 9:47 pm
Essential Bathrooms Ltd,
Go for a ST Monsoon with single impellor if you can find one, otherwise go for same make, double impellor and boost both hot and cold supplies.
It is currently Sun Jan 26, 2025 2:58 pm
