Possessed shower pump
hufri01
by hufri01 » Fri Nov 12, 2010 12:55 pm
Our shower pump has developed a fault. You set the temperature to where you want it and after a minute or two it starts running cold. You can only rest it by turning the water off an on again but this is no guarantee that it won't occur again. Any thoughts? Is it in fact the fault of the pump?
by stoneyboy » Sun Nov 14, 2010 10:03 pm
hufri01,
If you have a conventional system with a cold water tank in the loft I would suggest you see if the vent pipe is in the water surface.
hufri01
by hufri01 » Sun Nov 21, 2010 3:09 pm
[quote="stoneyboy"]hufri01,
end[/quote]
Thanks for the response. Are you saying the pipe should or should not be under the surface of the water? I'm guessing not.
plumbbob
by plumbbob » Thu Nov 25, 2010 5:26 pm
No it should not, but I'm not sure either way why that would effect the temperature of the shower unless it is plumbed up wrong.
Knowing what type/make of shower you have and how it is plumbed would be very helpful as other wise its really only guesswork.
by stoneyboy » Thu Nov 25, 2010 11:28 pm
hufri01,
Pipe should be well clear of the water surface.
It is currently Tue Jan 07, 2025 9:54 pm
