PLASTER AND PAINTING
7 posts   •   Page 1 of 1
cityred
by cityred » Sun Nov 21, 2010 6:58 pm
ive had the hallway walls plastered about 6 months, do i still need to use watered down paint before painting?
by stoneyboy » Sun Nov 21, 2010 9:53 pm
cityred,
YES it's even more important now the walls are thouroughly dry.
theshedman
by theshedman » Mon Nov 22, 2010 9:24 am
Hi cityred, the simple answer is yes. A mist coat is needed on all new plaster otherwise the emulsion will dry out to quickly and you will get problems with it peeling or bubbling.
toplondonchef
by toplondonchef » Mon Nov 22, 2010 11:26 am
Cityred,
In a word yes.
Raw plaster will remain porous regardless of how long it's been on the wall for and this will cause the problem if you just topcoat by "sucking" the water out of the paint far too quickly
Give the walls a light rub down with fine grade paper - 180 grit - then dust down and wipe over with a damp cloth, rinsing in a bucket of clean water frequently
Depending on the quality of emulsion used for the mist coat, you should thin down with clean, cold water from 20 - 40 % - depending on how thick the emulsion is. Dulux trade supermatt can take up to 50% water for a mist coat, it just depends on how much you want to spend and the quality that you want to end up with
Hope that this helps
Toplondonchef
decorating
by welsh brickie » Mon Nov 22, 2010 3:13 pm
use a weak solution of pva/water to seal the wall first this will prevent the wall from sucking in the paint
melitavejnovic
plasterboard walls and paint peeling off
by melitavejnovic » Mon Nov 22, 2010 7:37 pm
hello everybody!
I've just moved into my own flat and am doing some decorating.
I don't know anything about building work/materials so bear with me as I try to explain what the problem is.
I believe all my internal walls are made out of plasterboard. They are thin and sound hollow. I've been painting my bedroom today when, just as everything was going well, suddenly, a large area of paint just came lean off/peeled from the wall, revealing a dry, mat cardboard-like wall, brown in colour?! I am using a dulux super matt brilliant white paint, by the way...
What do I do to repair it? Please tell me in simple terms as I am not much of a diy specialist.....
Also, I got artexed ceilings in the flat. They look ghastly and dated, 'whiped cream' effect. I've painted the ceiling in the living room and it looks ok. But then, te one in the bedroom is peeling off, and falling off in dusty/chalky like peices?!
I'm now left with the ceiling that's half nice and half terrible. I will let the paint dry and just brush it off tomorrow and may even leave it like this. Unless someone has a beter idea? I've been told something about that upv super or similar sounding to use as a primer, but when I read the back of the tin, it says 'not suitable to be painter over with a water-based emulsion' which is what i'm using?!
Please give me some advice as I don't know what to do!
Many thanks, I really appreciate your help!
Mel
theshedman
by theshedman » Tue Nov 23, 2010 10:06 am
Hi mel, you would be better off posting this as a new thread then you will get answers that relate to your post alone. Just copy and paste your post into a new one. When you go to furum index just look close to the top of the page on the lefthand side and click new thread.
It is currently Sun Nov 24, 2024 4:10 am
