AEGIS Conservatory roof systems Gutter Clips
Conservatories are a great all-round addition to any home. Find help, advice and information on all aspects of this area.
sharkie1
by sharkie1 » Mon Nov 22, 2010 9:06 pm
I have an 8 year old conservatory and a number of the gutter clips are broken. They have the name AEGIS on them, but I beleive the company no longer exists. Is there a supplier still available with these clips?
kingfisherrc
by kingfisherrc » Mon Dec 27, 2010 12:19 pm
Could you post a pic of them?May be able to help
sharkie1
AEGIS conservatory roof system Gutter Clip
by sharkie1 » Sun Jan 02, 2011 2:41 pm
The top lug is broken on this pic.
It is similar to a K2 gutter clip but 1 or 2 cm longer.
kingfisherrc
by kingfisherrc » Sun Jan 02, 2011 7:07 pm
Hi thanks for the pic.The manufacturers no longer exist.All I can suggest is to either replace all the guttering and brackets with new gutters or alternatively, if you have some on the conservatory which are okay you may be able to spread them out equally around the conservatory then put some screw in clips inbetween to hold the weight.The gutters should be a common system (marshall tuflex for example)so just get some screw on brackets for that system.It may be marked inside the gutter length or on one of the corner pieces etc
Ta Mark
It is currently Sat Nov 23, 2024 3:55 am
