Faulty Shower
tinkerbell789
Faulty Shower
by tinkerbell789 » Mon Nov 22, 2010 11:03 pm
Power is there but no water, read somewhere most likely solenoid or pressure build up in showerhead, checked showerhead so most likely internal problem
This is the shower I have.
Google "showerdoc.co.uk/shower-spares/gainsborough/energy-1000x.html"
Question: Is it just a case of purchasing a shower then connecting up to old shower connections or do I have to buy a specific model, i.e. another gainsborough shower. On their site it has a link to replace an old model
Google "gainsboroughshowers.co.uk/Customer-Services/Replace-an-old-model/#q4005"
Not sure I want the shower they suggest wanted a more modern one.
Thanks for any advice
by ericmark » Tue Nov 23, 2010 8:29 pm
The diagram you have linked to shows just two components that will stop the water. However the problem is water and electric don't mix and unless you know what you are doing it is so easy to get a lethal shock from a shower.
Although the Part P does say like for like replacement is permitted the electrical regulations do expect one to do tests which without expensive equipment can't be done.
I would suggest that you don't DIY this job.
It is currently Tue Jan 28, 2025 1:20 am
