Can you use poly filler on wood which is used for walls
git
by git » Thu Nov 25, 2010 6:29 pm
I had a loft conversion and the builders are using poly filler on wood. Please advise any comments welcome. I asked why not using wood filler. The reply poly filler is life long lasting?
steve61
by steve61 » Sat Nov 27, 2010 9:40 am
No problem using polyfilla, as long as the wood will have a painted finish.
Hope this helps,
Steve :D
greengrass
Polyfilla on wood
by greengrass » Wed Dec 01, 2010 12:31 am
No problem I've been doing it for years, as Steve says if it's being painted over. Just make sure you rub it down flat with surrounding surface and fill and holes that usually appear after you've packed the stuff away.
Years ago in the dark old days it used to be sawdust and glue mixed then some used wall plaster or chalk mixed with glue which was hard to flatten.
Then lo and behold a there came to our land of plenty, oops! forgot I was in UK! land of less than plenty, a person who invented white and grey powder nad he called it filla and all the people in property building and mantenance work danced with glee at the filla because it is so easy to work with.the end. Sleep well..
It is currently Sat Nov 23, 2024 7:41 pm
