Freestanding bath waste confusion...
rarara
by rarara » Fri Nov 26, 2010 3:40 pm
Am going to install a freestanding bath and have it pushed against a wall. The hot/cold and waste will both be set into the wall and run horizontally, be tiled over etc, and due to the existing waste exit height into the stack, its impossible to run under the boards.
With this in mind, with a standard twin-skinned acrylic bath (ie a £500 job with wrap-around surround), is it acceptable to cut a hole about 10cm up the outer skin to allow the waste pipe to exit, and the hot/cold to enter?
Can someone please set my mind at ease before I order the bath online!
thanks
rarara
by rarara » Mon Nov 29, 2010 12:22 pm
anyone! surely someone out there has fitted a bath??
plumbbob
Re: Freestanding bath waste confusion...
by plumbbob » Tue Dec 07, 2010 8:55 pm
rarara wrote:With this in mind, with a standard twin-skinned acrylic bath (ie a £500 job with wrap-around surround), is it acceptable to cut a hole about 10cm up the outer skin to allow the waste pipe to exit, and the hot/cold to enter?
Sorry, but I don't get this. Cut a hole where, in what? If you mean the bath panel, then sure. Why not?
It is currently Wed Dec 04, 2024 8:04 am
