Problem radiator
Pistol Pete
Problem radiator
by Pistol Pete » Sun Nov 28, 2010 1:49 pm
Hi, I have a rad that is cold at top and hot at bottom. Valves are open , but no air is coming out when bleeding .Valves both work...... Any ideas.
steve61
by steve61 » Sat Dec 04, 2010 10:23 pm
The rad may be sludged-up.
You could try turning on the central heating, and shutting down/turning off all the rads except for the problem one
This will force water through the problem rad, then bleed all rads afterwards - worth a try...........
Steve :D
It is currently Wed Jul 03, 2024 6:00 am
