wall repair
neald
wall repair
by neald » Sun Nov 28, 2010 4:18 pm
hello everybody,i need to repair a wall that has had dado rail on,the are a few holes/patches that are from the liquid nails and pins that held the rail onto the wall,what i would like to know the best plaster to use to cover the holes i.e.multi-finish? thanks neal
JRS
by JRS » Thu Dec 02, 2010 8:44 pm
If they are not too big you could just do a couple of fills with easy fill, or you could get some one time which is great for small holes.
neald
by neald » Fri Dec 03, 2010 8:11 pm
[quote="JRS"]If they are not too big you could just do a couple of fills with easy fill, or you could get some one time which is great for small holes.[/quote] the holes aren't that deep and some area's are only the thickness of the emulsion on the plaster,would it not be possible to easi fill the holes in one fill? neald
JRS
by JRS » Sat Dec 04, 2010 6:50 pm
Should be fine just to fill then, May take a couple of fills to be flush.
neald
by neald » Sun Dec 05, 2010 7:48 pm
ok mate,i'll let you know how i get on
It is currently Mon Nov 25, 2024 12:32 pm
