I have a very old central heating system that includes: 2 water tanks in attic - one for radiators and one that fills when I use hot water. I have a boiler and a copper hot water cylinder in kitchen. The problem I have is this...
Control panel is set to hot water only. This works fine
Control panel is set to water and heating, only hot water heats.
There is a little box next to the hot water cylinder with a sliding metal switch. The heating will only come on if I pull the metal switch to one side, but it keeps sliding itself back. I have to jam it in position but I'm worried that I maybe damaging it. It feels mechanical, and I think it's electrically powered as there is a wire coming out of it.
Is it easy to replace this box? What's it called?
