plastering a previously tiled wall
generate
by generate » Mon Nov 29, 2010 11:19 am
I am renovating an old house in Spain.
I have removed all the old tiles from a bathroom and want to plaster then paint the walls.
There is a lot of old tile adhesive left on the walls, which is very difficult to remove. Can I just re-plaster over the top of it? The cement render underneath seems sound.
I want to end up with a rough / rustic look, so it doesn't have to be particularly smooth, just waterproof.
Thanks!
chris_on_tour2002
by chris_on_tour2002 » Sun Jan 23, 2011 12:43 am
you could use a thin bonding coat over the adhesive and float it off. then skim finish. that's what i'd be inclined to do.
dot & dab is another option.
It is currently Sat Nov 23, 2024 11:56 pm
