It's cold here in Wales and I'm belatedly getting to grips with frost protection for tanks etc in a bungalow loft. So far so good - no freeze-ups, but I intend adding some low temperature background heat to the loft.
To avoid acessing the loft, I want to install a small mains powered 'stat at high ceiling level in the kitchen with a remote sensor in the loft immediately above.
I need to switch about 5 amps, in the range minus 10 to plus 10. Ideally it would have a display and an LED, but not absolutely essentially.
Searching the internat has been a bit fruitless, Is there such thing?
Any help or suggestions are welcome.
