outside loo
steviedee
outside loo
by steviedee » Wed Mar 07, 2007 4:15 pm
this is probably impossible...but I have an outside loo (typical size 6ft x 3 ft) attached to side of house next to back door. I plan to fit a small conservatory porch over the back door which will effectively bring the outside loo more 'indoors' . I will change the door so it opens away from rather than into outside loo.
I wonder..if it is possible to actually fit a shower and small basin in there as well?? Has anyone seen this done?
thedoctor
by thedoctor » Fri Mar 16, 2007 1:44 pm
MANY OF THE ANSWERS TO YOUR POSTS CAN BE FOUND, WITH DIAGRAMS, IN THE DIYDOCTOR PROJECTS SECTION. CLICK HERE www.diydoctor.org.uk/projects.htm
Arrwa26
Re: outside loo
by Arrwa26 » Wed Jan 23, 2008 9:29 pm
[quote="steviedee"]this is probably impossible...but I have an outside loo (typical size 6ft x 3 ft) attached to side of house next to back door. I plan to fit a small conservatory porch over the back door which will effectively bring the outside loo more 'indoors' . I will change the door so it opens away from rather than into outside loo.
I wonder..if it is possible to actually fit a shower and small basin in there as well?? Has anyone seen this done?[/quote]
Steviedee
I was wondering whether you ever found out if this job was possible, and if so whether you have gone ahead with it?
The reason I ask is because I would like to do exactly the same, mainly building a small porch to integrate the outside toilet and small coal house with the rest of the house.
Any information/advice would be appreciated.
Regards
p.s I did do a search in the projects section but couldn't find anything directly relevent.
It is currently Mon Jan 06, 2025 9:27 pm
