washing machine leaks after water supply was frozen
somersetsaint
by somersetsaint » Sat Dec 04, 2010 2:31 pm
My machine is outside in shed, the water supply was frozen but is now ok. However the machine leaks even when not switched on. Any ideas why?
determined
by determined » Sat Dec 11, 2010 5:58 pm
Water has frozen in the machine, expanding to crack the pipes.
Water is likely to be delivered to the machine under pressure, and as there's now a crack, the machine will leak even though it's not on (as water is sent to it under pressure).
Rgds
It is currently Sat Nov 23, 2024 12:59 am
