Log burners
Ressy
Log burners
by Ressy » Wed Dec 08, 2010 11:25 pm
Has anyone got any advise on fitting a log burner in a ordinary fire place
Perry525
by Perry525 » Mon Dec 20, 2010 12:23 pm
When a fireplace and chimney are designed and built, the designer usually has a particular sized fire and fuel in mind.
If a fire is too small or burns too cold, you may well have a problem.
While the idea of burning wood seems to have caught the Governments imagination, the reality is not always that good.
If your chimney is old, It may not have been parged, or lined to a satisfactory standard, it may be subject to condensation.
If wood is not seasoned and dry, if the chimney is not hot enough this may well lead to deposits of tar.
If coal and wood are burnt at different times, the coal will product sulfuric acid the wood condensation and the two will combine to dissolve the lining of your chimney, with the wood leaving deposits of tar, this can lead to a chimney fire.
It is currently Fri Nov 22, 2024 3:49 am
