New slate roof... tiles slipping and cracking!
DrRocketMan
by DrRocketMan » Mon Dec 13, 2010 12:50 am
We had our slate roof re-membraned and re-slated (with new slates) Nov09. Since then we have had to have the roofer back about six times to repair a total of about ten slipped slates. After the latest cold spell last week I noticed two more have slipped and one has cracked in half. I will call the roofer tomorrow.
The roofer seems as disappointed as I am when I ring him up and he turns up resonably promptly to replace the damaged tiles. He questioned the supplier the last time who told him that it is because the roof is south facing!!!
I'm at the point now where I have no faith in the quality of the materials used. Does anyone have a suggestion as to my next course of action or has anyone experienced this problem themselves. I have emailed the NFRC but since the roofer was not a member I doubt there is little they can do.
Help and advice much appreciated,
Regards.
by stoneyboy » Tue Dec 14, 2010 10:02 pm
DrRocketMan,
If the slates were new and they are fixed according to good roofing practice there is no reason why any should slip.
You are just going to have to keep getting the roofer back, you are lucky he is prepared to keep returning.
DrRocketMan
by DrRocketMan » Thu Dec 16, 2010 10:53 am
Many thanks stoneyboy... incidentally do you say "you are lucky" because you think most roofers aren't this consciencious or because it is outside of my rights to expect him back.
For info I have found out that the supplier of the materials [u]is[/u] registered with the NFRC so I will see what they have to say.
If anyone has any experience or advice in getting independent inspections I'd love to here about it.
bethesdaslate
Slates slipping
by bethesdaslate » Fri Feb 18, 2011 9:55 am
Hello
You should not be loosing slates like this if the roof has been fitted correctly and / or the slates are of acceptable quality.
A slate roof fitted correctly should be able to withstand severe weather conditions with no problem, much more so than concrete tiles for instance.
If you are still having problems I am an independent Roofing Consultant specialising in Slate Roofs and Lead work and would be pleased to advise further if necessary.
Jon
It is currently Sun Dec 22, 2024 1:21 pm
